Transfercase fluid
sledfreak
south of 80
I know in the manual it says motorcraft transfercase fluid but isn't really trans fluid? and if it is what do you guys think about running royal purple atf in it.
rlpzzz
Houston
FWIW, I've heard some negative opinions on Royal Purple but I recently changed my and used Mobil One. It's easier to find and cheaper than the RP.
sledfreak
south of 80
I run mobile 1 for the motor but this is going into the transfercase.I never heard these negitive opinions on royal purple other than it is not cj-4 rated.I used their gear oil for years it works great, don't need a friction modifer with it for locking diffs either.
outacntrl
Clearwater, KS
It looks like trans fluid but it was cheaper so I went ahead and got the right stuff. When I asked around the dealer I was told they use trans fluid if they don't have the other stuff but nobody could tell me what the difference was.
Sent from my DROIDX using Tapatalk
rlpzzz
Houston
I was referring to the Mobile One ATF. I may not be understanding your last sentence but I would not use a gear oil in the transfer case.
WoodBoy
Alabama
I think these trannys call for Mecron V right? I cant remember what it was but they changed it. Maybe it was Mecron V and they changed it to something else
amarillo250
Montreal, Quebec
after replacing my transfer case a transmission builder told me to use the mopar tranny oil, it stands better up against the head. 20k later, my fluid still looks like the first day and it works great so far, even with negative 15-20 on the thermometer.
