Transmission Flush
2good2Btru
Houston, Tx
Took my truck for a tranny flush on Wednesday. It has 33k miles on it. Has been tuned since 2k. Tranny was perfect, no complaints. Picked it up on Saturday, and its just shifting like crazy and if i lightly step on it about 60mph, the converter unlocks and will not lock up again after I let go of the pedal.
Was throwing two codes, don't remember the exact numbers but one said "Shift Solenoid or Stuck Off" and the other one said "Transmission Friction".
What the hell happened, it was working perfect?
Thanks
2good2Btru
Houston, Tx
They told me they put the same stuff that it had in it. What is the correct fluid and I will talk to the guy first thing in the morning.
Spatel23
Olive Branch, MS
First thing I would do is ask them, "well what did it have in it"?
They cant look at the fluid and tell what it is.
They should have used Mercon SP or the newer LV. You can mix the two.
If they used Mercon V=BAD.
Again, find out what exact fluid they used before you divulge any information of what should be used.
