SD pad has the same capacity...
Yep....more fluid just takes longer to heat up and cool down.
If you replace your stock pan with a 4R100 pan you'll need 16 quarts. The 4R100 pan doesn't hold any more fluid than the E4OD pan.16 quarts for a stock OBS and stock trans cooler.
Both of these figures assume you are also draining the torque converter by removing the torque converter drain plug.
