NyCowboy87
Been thinking about geting rid of the triple setup. Yes it works great and yes Im going to stay with a triple setup but the truck is slowly turning into a dedicated puller so Im going to re configure everything making it easier to put air shutoffs on (required in the class I want to pull) and make it overall easier to work on. So instead of throwing all the mounts and piping into the scrap heap I would like to get rid of it to someone who will get use out of it. I will sell it as a complete kit with all the chargers, mounts and piping, and oil plumbing. There are a couple mods that have to be done such as installing oil drain bungs in the passenger side valve cover and oil pan, also need a 3" body lift and will need to trim the heater box and passenger side inner fender. This is also setup to retain the factory a/c. All pipes are powder coated along with the compressor housings, all the exhaust plumbing and turbine housings are also ceramic coated. I have countless hours into fabing this up and making everything fit, not to mention the cost of everything, Im asking $6,000but will consider reasonable offers. These spooled good on the street and will clean up 450/400's on a hot street tune no problem at all, pulling/drag tunes are cleaned up to a decent haze.
