Pwnm30rdi3
Hey guys!
As many of you may remember, I have been having troubles the last 7 months with a rough and erratic idle.
I tracked my problem down to the SRP 1.1. The SRP 1.1 has a small internal spring that broke and ran through my injectors. I upgraded to twin terminator HPOPs and sent my injectors to Full Force for a tune up and flow.
I got everything back together about 3 days ago. I put 150 miles on the truck and now it's starting to run like crap again.
Videos of how she is running.
High Idle:
http://youtu.be/tqAqN_xwu1s
Idle:
http://youtu.be/9I7wcbfTYqk
Now I have the following codes:
P0603 - Internal Control Module Keep Alive Memory (KAM) Error
P1282 - Injector Control Pressure Higher Than Desired (engine running)
P0344 - Camshaft Position Sensor A Circuit Intermittent (Bank 1 or Single Sensor)
P0478 - Exhaust Pressure Control Valve High
P1212 - Injector Control Pressure Lower Than Desired (engine crank or run)
Seems like something is going wrong with this thing left and right.
High Idle:
Idle:
