AllanB
I installed a DJM lowering kit several months back. Two things happened when I did this. FIrst the harmonic dampener( I guess that is what they call it) that is on the drive shaft started rubbing the exhaust. Well I figured that I wouldn't worry about this on a test drive, I would drive it and adjust for pinion angle. I didn't make it very far and the harmonic balancer came loose. Is there anyway to put this back on. I can spot weld it, if that is ok and it will still work. If not, who sales a drive shaft?
Second I have noticed that when I have it at WOT, and I get out of it at say 70mph+ the rear end will get a little squirrly. When your running 100mph or so, it is more noticable. The other day I was in a curve, not a real hard curve, but I had it to the floor, in the middle of the curve I got out of it. It got really squirrly, enough to scare the crap out of me. I have checked and double checked the supension and everythng is tight. My guess is (with the springs flipped from lowering it) it is the torque reaction to the leaf springs? Kind of like axle wrap but at a higher speed. I know it isn't axel wrap, but I am guessing the same theory. Time for Caltracs??? Or is something else causing this?
