96OBS
Hey guys, my truck has done this since o got it but now it seems worse, when I crank up my truck it catches and sounds like a sputter when it cranks over then is normal. Not sure if this is normal thing or what. You know how a pulling truck sounds like when its trying to spool up? Kinda like that and only does it as soon as it cranks over. May be fuel pump? I also think my fuel pump is the culprit of the fuel leak. Its soaking wet around it and I dry it with brake clean driven it and its wet again.. not sure.
