JD3020
So i got bored last night and since i have a massive pile of parts here ( Hydra, T4 mount with 468, some DIY HPOP stuff, and a few other things) i decided to put my 17* pump on. I pulled this pump off my project engine, i personally drove the truck before i pulled the engine out and it ran extremely well. Last time it ran was early-mid spring. Got the engine home and on a stand 4-5 weeks ago and i pulled the HPOP out then, its sat in a plastic bag on my bench since.
So last night i pulled my truck up to the garage to tear into it, truck was running like normal. Swapped HPOP's, re-used my old IPR, and had it cranking in about an hour. But thats as far as its made it. It cranked, and cranked, and cranked some more. Commanding 88% DC(IPR closed) but its only showing about 33psi on my scanguage. I have oil in the res, i've cracked the lines and plugs and i'm getting some oil to them as well. But it will not build any pressure. I've tried a couple IPR's. Cleaned and inspected everything the best i can, and i don't see any oil leaks. It honestly feels like i've been cranking this thing longer than i did when i was trying to get this engine going last winter, after i had it all tore apart on a stand and went through it.
The only "odd" thing about this is i used a Fel-Pro HPOP gasket as i had one laying here, not sure if maybe the gasket has failed and allowing a HPO leak at the front cover, which IDK if thats even possible. Just has me scratching my head as i've done a couple HPOP and IPR swaps, put an engine in it, put in 4 different set of injectors, and this is the first time i've had an issue getting it fired up.
