kmanxj
My truck wont move!!! Its sat for two days. It wouldn't start yesterday morning -16* here. So when I got home from work I fired it up and let it run for about half an hour (never put it in gear). This morning I started it (only -6* this morning). And let it run for about half an hour. Now when I went out I noticed the key was forward a little bit. Blower motor and radio werent on, so I turned it back a smidge and everything kicked on like it should. Went to put it in gear to leave and it wouldnt do anything. Tried every gear and nothing. Shut it off and restarted still nothing. Crawled under and moved the cable around and it doesn't seem frozen or anything. Checked all the fuses and all where good. What else should I look for? 97 f250 E40d
