woodduck97
Buddy has a E99 F-350 with about 200k on it. Hooked scanner up had these codes in it. Had the chip pulled out to rule it out.
B1201 Fuel Sender circut fault
U2016 Signal Link Fault (NON SCP) Short
B1352 Ignition Key- in Circut Fault
B1302 Acc Delay Realay Coil Circut Fault
PO603 Internal Control Module KAM
While I had the scanner hooked up looked at ICP and IPR seemed to be working ok. Looked at RPM next and it was jumping all over so we replaced the cam sensor fired right up. Let it run for 30 minutes or so. Go back outside shut it off. I said well lets hook the chip back up. When we hooked it back up the light on the switch was on with the key off (DP Tuner). Turned the key on tried to start it nothing. RPM wasn't moving WTS light was not coming on, fuel pump was not running. Any ideas what to check? kinda has us in the loop because it also has a draw now since this problem began the other day.
