Well I moved my truck this morning, everything was fine. Went out with the family to head to the hardware store, jump in and turn the key and nothing, I mean absolutely nothing. No gauge movement, no radio kicking on. It's like the batteries are completely dead but I know that's not the case. I turned the key a couple times thinking some miracle will happen and the truck would start, sadly not the case. But i did start hearing a "bzzz, bzzz, bzzz" under the dash. Crawl under and it seems to be the factory Antitheft system (right in front of the door chime box under the dash). It sits there and buzzes the same rhythm it usually does if I open the door without unlocking with the key (like when the windows are down and ND rend I hit the button). The lights don't flash or anything all I get is the buzzing sound from the box and absolutely no power to the ignition. Has anyone else had this happen to them, any way to diagnose it or bypass it? Need to try to figure this out myself, on disability from work and don't have the funds to take it to a shop to figure it out. Thanks for any opinions or advice.
