Tuners and unplugging the EGR
Dzchey21
wyoming
If the tuning is EGR off it wont cycle the egr at all, or at least it shouldnt. Unhooked will probably ensure that it doesnt cycle at idle to keep the EGR valve from sticking.
The tuning that i am running doesn't cycle, just H&S base file that i have moddifiend (not the egr stuff)
02bigstrokin
Mine is throwing a p245a code after full egr delete. Everything is unplugged and removed, I wonder if I should plug sensors back in and just tie up out if the way?
drunk on diesel
I wish they had a base file that cycled at idle. I like that option on 6.4's. Easy to go back to on-road calibrations without worrying about stuck valves, etc.
drunk on diesel
butterfly valve is used to choke intake flow to allow greater EGR flow, to control A:F to control combustion temps, and as a shutdown valve when you shut the truck off
bigrpowr
<How I Fly
Administrator
did you get the tuner from me? if so , call me Friday and i'll get you squared away.
