Turbo Mini-Bike Build
d.evil
Sparks, NV
Figured I would start a thread on my little project we have been working on for a couple months.
It started out life as a Doodlebug mini-bike from Kragens with a little 3hp engine on it. That was quickly removed and swapped with a 6.5hp engine from harbor freight. During the install of that we added a billet connecting rod, a cam with more lift / duration, and a Mikuni slide carb.
I've always wanted to build a turbo mini bike, and figured this would be the perfect platform to finally do it. I sourced a knock-off IHI RHB31 turbo on eBay (smallest commercially available turbo) and went to work.
Currently we are setting it up as a draw-through system, but that may change once its together. I have read that it is hard to get to run right with this arrangement, but will give it a try for now.
On to some pics!
Rough mock-up:
Up-Pipe building:
Finished Up-Pipe:
Header Mock-Up:
Intake Plumbing:
Header Done:
Fuel Cell:
Battery box & final boost gauge location:
Thats where it sits as of now. Just need to finish the oil pump mount, wire that up and do final assembly & hope it starts!
Once its running it will get torn back down for a new seat cover and the frame / forks / fender powder coated. I'll post more pics as progress continues.
