Turbo options
97BambiBasherPSD
Edinboro, PA
So I'm lookin to get a new turbo for my dually. It's an 04 with stock sticks. Iv talked to barder a little bit and he suggests the 1.5 or stage 2 turbo. I'm stuck between barder, mtw, or buying a powermax. What has everyone run? A little run down on the truck is that it's a tow rig so I need to it not get too hot since I'll have 20k hooked to it on the weekends. I need a little room to grow with it since I would like to get a little bit bigger injectors for it at some point. Iv already got a built tranny and the egr stuff done. Just need to do studs this summer. So again I would like some insight as which turbo to run.
BARDER
MAD TURBO WERKS
GARRETT POWERMAX
And go!
Thanks guys!!!
Sent from my Pear phone 5 using Tapatalk
1fastTRX
I'm sorry, but did you say something? I was busy staring at your avatar! Lol
You can't go wrong with a powermax, but it will still have a cast wheel. I can't say enough good about Barder! I have his stage 2 with billet wheel. Max egt's are 1100ish on a race tune. I've only towed once and was about 8-10k (2wd f250 w/service body on a 16ft double axle trailer). Trailer had a tire running hot so I limited my speed to 55-60 mph. I couldn't tow in OD since rpm were so low (1500rpm; 35" tires and 3.73s), but it worked great! I couldn't break 1000 degrees going WOT uphills. Cruising egt's were 800-900 depending on hill. I actually stopped looking at the gauge since it never got out of control. Im guessing you already have 4.10s being a dually? If so I would jump at the stage 2. I don't know if MTW has been able to improve turnaround time or QC lately so I won't go beyond that about them.
Sent from my SCH-I535 using Tapatalk
97BambiBasherPSD
Edinboro, PA
Wow that's the response I was looking for. If I did go with the pmax I would get the WW2 for it. Do you have stock sticks in it right now?
1fastTRX
Yup. Stock sticks. I'd like to get bigger injectors, but that's pretty far down the road for me. With stock injectors this thing is still fun to drive
Derkperk
Twin cities
Very distracting. :drool:
I think you'll get a better value with the Barder. There are a lot of happy customers. The powermax is tried and true but you'll have to make the call.
Powerstroke214
Baton Rouge, LA
I vote barder stage 2.
I'm planning to do either an 03 turbo w/ a WW2(college budget), or a BTS stage 2 or a non VGT setup. But I'm not towing anything. I also plan to move up to a 175cc injector.
Mixedbreed
Laramie, Wy
the Pmax doesnt flow that much more than stock even with a billet wheel. i have one and want something bigger. but it is a good stock replacment.
swinky
Eastern, Nc
Something tells me I'm going to be a guinea pig for said setup lol
Sent from my SM-T210R using Tapatalk
Powerstroke214
Baton Rouge, LA
No…:lookaround: what makes you think that!? LOL
Yea pretty much, I saw what you were planning and I was looking to do something similar, and you seem to have a head start lol
swinky
Eastern, Nc
You'll have the head start when I blow the fugger up. 220k miles lol
swinky
Eastern, Nc
Op what I think what we need to know is how big of an injector you're going to go with. If you want 155s I'm going to suggest a turbo for 175s. Cause that's what you'll most likely end up with lol sad but true.
swinky
Eastern, Nc
I'll probably end up goin with a 175 since I tow heavy with it
I think a 175 with a 30% nozzle would be a great injector. the 68 from barder should clean those up completely (probably overkill). Not sure how it would be towing and how the lag is. Maybe Oliver will chime in on that. Even then with a stage 2 I bet you could get a good cool tow file written and be mid 500s on a race file when you want to play. Reg return, guages....... all that jazz if you don't already have it.
97BambiBasherPSD
Edinboro, PA
I'm workin on the rr and gauges. Iv been leaning towards the 2 so I'm hopin that will do good with stock sticks for now. Anyone run it with stock sticks?
swinky
Eastern, Nc
^^^ stock sticks
