kadeninabnitt
Would a stocker handle stage 2injectors? wanting to get a set but haven't got enough coin to get a turbo as well. just wondering if mine would survive untill i could get one.
I'll just have to try my luck and see if it holds out
If you intercool it & don't drive like a pissed off white boy all the time you should be okay.
I've been running my 238/100s for a few months now on the stock charger. How long it lasts is all in how you drive it.
I have a 95 Adrenaline HPOP stage 1s regulated return zf5 south bend con o superduty lift pump and I can melt the clutch if I want to. I should have gone con ofe. Also con o clutch uses a luk disk
