Turbo rebuild
97BambiBasherPSD
Edinboro, PA
So I took my turbo apart to rebuild it and can't get the comp wheel off the shaft. How does it come off and any suggestions? And any sorts of tips for rebuilding it?
Sent from my Pear phone using Tapatalk
Justin@DP-Tuner
I just put a vise grip around the nub on the exhaust side and used an impact to take off the comp wheel.
97BambiBasherPSD
Edinboro, PA
Ok well which way do you have to take it off? I mean is it the standard righty tighty lefty loosey or backwards from that? And is there any chance of snapping the shaft?
Justin@DP-Tuner
Standard stuff. Lefty loosey. I doubt you will snap that shaft. My turbo had 230,000 miles on it when I took it off. It took a few tries, but if eventually came off. Just make sure your vice grips have a good grip on the little nub.
