Turbo shaft tolerance
TD-5
British Columbia Canada
Does anyone have the specs for maximum axial & radial play in the shafts on both these turbos.
Of course if the wheel is contacting the volute housing its junk, but how much play can these be run with before it should be condemed?:hammer:.
.003"-.005" axial and .015" - .020" radial is what comes to mind for these sized turbos, but I'm probably thinking of something else and out in left field.
