U bolt info needed
PTSUPERD
Hey guys. Looking for some u bolts. When I did the lift, I sourced u bolts from a local place here that does them. Functionally they are fine....but have developed surface rust etc. I "think" Icon offers some that are not the yellow zinc and arent chrome. Like a satin metallic look.
Any info so I can order? Parts #s etc would be great.
jdgleason
Fort Collins, CO
I don't have any part numbers for you, but I do know that ouo has some rowdy u bolts that you might like. I know the ones I've seen from their traction bar kits are just about a piece of art in themselves.
FX4 F2-Fifty
East Houston/San Marcos
I've got some new ones sitting in my shop at home. Front and rear that came with my pro comp 6.5" lift. Probably not what your looking for but If interested I will be there this weekend.
Sent from my DROID BIONIC using Tapatalk 2
B.Warning
NE Missouri
I got a spring shop here that builds them, that's all I run. I guarantee them to be stronger than anything else you can buy. I also don't have a problem with them rusting here in north east mo. I can get you a set for roughly $40 if you want.
BK39
Texas
sand and paint would be my option. I had a big rig service center make me some with my old set-up, painted them before I put them on, never had any issues with rust.
NotStock
Tucson, AZ
There is a "black zinc" or "black oxide" coating that they can put on ubolts. If you want, I have have my local plating shop do a batch for you. Just let me know what diameter and length you would like. I bend inhouse, so the only turn around time would be the platers.
PTSUPERD
Thanks Trevor. I'll let you know.
91turbogsx
Gardner MA
I can't speak for the 3/4" U bolts from them but I'm pretty sure my 5/8" u bolts that came with my traction block setup were boxed Icon.
NEVRNF
NW IL
Hey Gare, I might have a set of Zinc plated ones sitting down at the shop. I will measure them if you are interested.
NotStock
Tucson, AZ
Sure Tony. let me know. They in good shape?
If your not changing the size of your bolts, you could take them to a local plater. Normally wouldnt cost more than $20 or a case of beer for something like that. Be ready to hold your breath while your there though. The air in those places is terrible.
