U joints
MossBack
UTAH
Thanks! I rebuilt my front when I pulled my trans for tq swap.
I am curious of how many others ditched the non-grease able ones. I did as part store only had grease ones and I am under my truck once a week and grease my ball joints and steering components . And when I rebuild the front end am also replacing them. If anyone else has I would like to hear on results. I use amsoil full synthetic water resistant grease
Tom S
I stuck with non-greasable ones since they seem to do a good job lasting if all is in order.
MossBack
UTAH
That is understandable but my background is of working on a 1,000 + truck fleet of ken worth t800 tractors and while I was a lube tech every truck got greased up. And for what it's worth the 100 of thousand miles the trucks go it seems like the grease able u joints hold up given they are greased often and done properly.
FrankTheTank
Cecil County, MD
Look into NEAPCO joints, i like them better then spicers, they seem to have a better tolerance, feel heavier, and are made in Pittsburgh PA.
Old OutLaw
Suthren OryGun
the only joint that lasts inna log truck is Spicers...Naepco's are junk in comparison..... I've changed hundreds of them.
I just did the rear driveline in my 1-ton and it got Spicers.
Old OutLaw
Suthren OryGun
the Neapco joints are softer, far as I could tell, they just didn't last as long as the Spicers, the crosses would lose the hardfacing and start vibrating, I wouldn't use them personally.....
and I worked the Logging - Trucking Industry for 40 years, as a driver-owner-mechanic....
FrankTheTank
Cecil County, MD
Good to know... i will stop recommending them then. If they were softer that would explain why they looked beefier and felt heavier. To compensate for the weaker metal
