kamikaze jr
I just got done replacing my stock compressor wheel with an xdp x-wheel and everything went pretty smoothly aside from one snapped bolt got the taken care of .. But my queston is
I'm not sure if my up-pipe is seated 100% to my exhaust inlet once everything was done I went for my first test drive had no boost pressure went had my buddy look under the hood while I throttled up n immediately saw smoke comin out from between that 90* exhaust y pipe and the turbo inlet on the exhaust side . So we went back over it n got it tight as possible (careful not to snap the t-bolt ... Again) and now I have boost pressure but not nearly what I had stock
Also the v band clamp tht came off wouldn't come together enough to get the stock t-bolt thru to get the nut on so we used a 6" lag bolt
ANY TIPS OR SUGGESTIONS GREATLY APPREICIATED.
