Upfitter harness question
JrStroker
Ahead of the competition
So my truck, 08 F250, didn't come with upfitter switches. I've heard that some trucks already have to harness behind the dash. Anyone have any pictures or info on how I figure out if I already have to harness. Thanks guys.
300000 and counting
Ohio
There will be a little square plug with 6 wires plugged into the back for your cubby hole, if it doesn't have one the harness with the relays are relative cheap. I put 05-07 switches in my 2001 I just got a pig tail and wired the pigtail into my own relays
vr6dub
Idaho
When I did the upfitters in my 08 I purchased the switches with the wiring harness/relay pack. My truck and I believe most trucks do not come with the actual harness per say, but there is a stock wire harness plug way the eff up near the firewall and gas pedal that does connect to the purchased upfitter harness.
JrStroker
Would anyone maybe have a picture? I know when I had my center dash cover off there was a lot of unused plugs that were hanging back there. I'm guessing this one would be behind the brake controller/coin cup
taterthedog
Canada
Dustin put a post in the Library section under 6.4 Tech with all the info about the upfitter switches. Lots of other good info too.
