Upgrading.
Twan
Berthoud, Co
What is the difference noticed with 50% nozzles vs 30%?
I lost 5 injectors last night so I'm getting 175's just can't decide on the nozzles.
I'm looking for turbo spool up. I will be running trany only tunes, to a small tow file.
Thanks.
Vengeance
Thanks.
Twan, with what you tow, 30% is what I would go with.
ajbond
I did a 175/30 and the power is great!! I tow 5k lb up a 6% grade @ 6000ft.. My tow file is from TSD and work well.. needs a few tweak but the truck only roll on select weekends to snowmobile.. I pull a 19 ft enclosed with 3 sleds and if I stab the go pedal it will light the tires..
I have not hooked to my 17k 5th yet with this combo but there is no backing out now...
I also have tunes from Gearhead but he took a bit too much persuasion to tweak a file so I went with Chris to dial in and then I'll approach Matt with my findings..
No regrets with the 30% nozzles.. I actually installed a P.I. T.C because of the power on tap made me nervous. .I have yet to run a full fuel file.. no need.. my 8k tow is faster than my stock race.. lol
Redneck6.0L
When you say lost c 5 injectors. All contributions faults or shorted low faults
Twan
Berthoud, Co
image.jpgI had a fault code on #1.
The tech sent me this photo.
