Urgent help needed guys!!!
KingRanch6.0L
West Houston
I just got my edge monitor installed and my fuel psi is reading 30psi. i know this isnt good i dont know if the sensor is off or what.
Plz help
Gearhead
you have an external add-on sensor right? the 6.0 does not have a factory fuel pressure sensor....
KingRanch6.0L
West Houston
showphoto.php
this is what i have.
OBS F350
Burlington, IA
He's asking if you have an aftermarket sensor that is like tapped into your fuel filter cap or somewhere like that. Because there is no sensor on the 6.0 to read fuel pressure from the factory. (As far as I know atleast). Does the truck run fine?
TooMuch03
West Bend, WI
Yup, sensor in the test port on your fuel bowl. Do you have a sensor for your Insight. You would have had to install it separate from the simple OBD II plug on the Insight. If not, you should get one or get a gauge. Maybe you have no problem. At 30 psi, I would suspect it starts very hard, if at all.
TooMuch03
West Bend, WI
Mine didn't start with 25 psi :shrug:
But that was a long time ago, some dumbass forgot to put the secondary fuel filter back in :badidea:
