Vacum Pump ????
purpleheart350
Rokwall, Tx
Ok so yesterdayI heard squeaking coming from the unfer the hood. So I pop the hood and the vacum pump is squeaking :fustrate: , but its not from the pulley slipping it is coming from the pump kinda. Well the pulley rod is moving in and out and when it does it squeaks really loud and its annoying :mad: . It only squeaks when the pulley is pushed out (and that is when it is lined up, when its in it isnt lined up with the rest of the pulleys). Well do I have to replace it or is there a way I can tighten it.
Tom S
My read of what you posted = time for a new vacuum pump.
Biggreen96
Visalia , CA
I had mine go out on south i405 in socal. Not a god feeling trying to get my truck to stop with manual brakes in rush hour traffic when your in the fast lane
MossBack
UTAH
Better change it and I recommend u get a Ford one. I went through 3 from Napa b4 I went to Ford and. So far I have 20k miles on it with no problem.
However I do keep a spare belt and pump under the back seat. Just my. 02
sent from my iPhone killer
purpleheart350
Rokwall, Tx
Yea I keep two belts in mine, long story lets just say the auto zone guy was a retard, along with different size hoses. I have a parts list that I wanna get and keep in the truck but the ol lady say I dont need it till it really need it. One of these days she is going to be with me and we are going to get stuck out some where then I can say "I told you so"
cowboy_dan
Brownstown, pa
I printed off the OBS parts list, and it saved my butt on my trip to Cali.
My vacuum pump dumped all it's guts across the interstate in Nebraska. I coasted to a stop 50 feet from the 110 mile marker on I80. I never heard a thing. No squeak, no squeal, no growl, nothing. Only reason I knew something was wrong was because the steering was hard. The shaft of the vac pump finally destroyed the bearings enough that the belt slipped off and I lost power steering & alternator.
The NAPA I called couldn't find the pump part number to see if they had one in stock, but they could cross-reference the fomoco number to their number.
But, since I didn't have the pulley pressing tool, I shelled out $375 for parts & a tow. What would have been a $150 bill more than doubled.
FWIW, Steve of Steve's towing & recovery from Julesburg, Co is a really nice guy. He used to be the PSD tech at the ford dealer before he went independent and opened his own shop.
cowboy_dan
Brownstown, pa
Pictures of when mine failed.
cowboy_dan
Brownstown, pa
More pictures.
Out of both bearings in that housing (at least, I think there were two bearings), there were exactly 2 balls left when I unbolted it from the flange at the side of the road.
Just 2 days ago I was under the hood checking out something else unrelated and found the plug from the back of the housing. It got blown out of the housing and jammed between the power steering pump and the LH exhaust manifold.
When I started that morning, there was absolutely no noise from the pump. It basically went from operating just fine, to completely grenaded in 250 miles. No warning what so ever.
purpleheart350
Rokwall, Tx
Well i went to NAPA because ford couldnt get it for 3 days and no one else had one, and I need my truck. Temp fix for now till i get it ordered from Ford. Well whenI took off the pulley, I saw what had been making all the noise. The bearing housing (whatever you wanna call it) had explodedand there was only 3 balls left. I dont think I would have made it any furthere than I did today.
MossBack
UTAH
Nope. The last time mine went I was in between towns and in a dead spot. Good thing I caught a lift to next gas station. Must be my good looks idk
zilla68
Moore Oklahoma
mine went out about a month ago, driving home one nite and started chirping. got home backed in and shut it off. Next morning jump in the truck, fire it up, no brakes no steering, jump out and there is the pulley laying on the ground.
