MrOneEyedBoh
- Joined
- Feb 24, 2013
- Messages
- 799
- Reaction score
- 0
So long story short, my cousins wanted me to make them some box mods for vaping. I bought parts in bulk, thus leaving a few boxes left over. There's many ways to build these but I did my own thing. These are heavily potted because of the high amperage. Just a personal choice, some don't pot at all. Potting isn't going to hurt it, it just doesn't look as pretty inside the box lol.
They are 20amp ( yes, 20a ) dual 18650 mods. They have the Raptor chipset, utilizing dual fuses along with reverse polarity protection and zeners. Also includes dual capacitors off board as well.
The boxes also have a digital voltmeter that reads both actual battery voltage ( shows battery life basically ) and it can show actual vaping voltage that you selected. The selector switch doubles as a lock out switch to prevent accidental firing in your pocket. The switch I an on-off-on slider switch.
Voltage is user set by utilizing the top mounted potentiometer. Low is ~3 volts to 6.0 volts. These builds work VERY well on a sub-ohm parallel or dual coil at around.5-.6ohms.
They also have the standard 510 connector with the larger standard push to fire switch. The switch isn't a cheap plastic body, these are metal switches.
Since these are handmade, there are some slight imperfections here and there. Nothing major by any means, but I wanted to put that out there.
You're going to want some good 30a batteries that are true high drain for this mod. Battery choice really makes these shine.
I've tested them and they are ready to go. Obviously with anything electrical, there is no warranty. But I guarantee they work just fine. I also have some no nicotine juice I bought to test these out I can throw in with the sale. I also have the atomizer tank, 24 and 26ga kanthal wire plus (2) genuine Sony VTC3 batteries. So basically if you're looking to get into this, I can set up only one complete package.
Price is 180 plus shipping. Or if interested in the package deal , we can work something out. I'd even do trades possibly.
