Vertical EGR cooler bracket
kyle43335
take it all off...
even the catalyst pipe. drill the block off plate for 1/4 pipe,put the bung for the ebp in that plate. re bend the ebp tube. done.
WoodBoy
Alabama
Make sure it comes with new exhaust manifold bolts before removing horizontal bracket
CT9AIX
MA
Remove everything. It creates so much extra space on the engine when gone.
capt dong
Houston, TX
flo pro instructions say to remove the vert cooler bracket. theres another small bracket that covers the thermostat housing. i removed that too. makes changing stats so easy.
HD-tech-NH
5150 on two wheels
Mine didn't and it doesn't in the instructions on thier website. I left the vertical bracket in place for now. I will remove it later. The instructions are in the link below.
http://www.flopro.com/tech/mnl/ec64.pdf
Off subject, but your avatar is awesome! LOL
Thanks Duder!
I have to say you hear a ton of stories about nasty intake build up. Mine was pretty clean. Just a little soot.
HD-tech-NH
5150 on two wheels
capt dong
Houston, TX
i thought mine did. but then again i used 3 different set of instructions one from rcd and the other from sinister i think. anyways good job!
pmiller75
Mchenry Il
When you remove the factory intake and use an after market one what do you do with the the 3/8 hose that runs from the degas bottle. Also what about the 2 electric connectors do you just tape or tie them up?
