Vibration Damper install
Homesteader
Can a longer bolt be used to start the damper onto the crank until the original bolt can reach the treads? Also is there silicone that needs to be used behind the washer? I thought I read it in a manual some where.
Thanks
brownie83
Catawissa, Pa
i just used the stock bolt without the washer, the once installed took out the bolt and installed the washer. i did use rtv on the key way. thats where it was when i pulled it, and i also read somewhere to use it...so far so good.
Homesteader
So what did you use if you did not use a washer? I think it still needs a washer but must be a thin washer. Now you mentioned the rtv I did noticed some on the key way. I have some extra motorcraft RTV for that.
brownie83
Catawissa, Pa
im sorry...you use a thinner washer...not sure of the size, but i just grabbed it from my stock. reread the post and the fingers were working faster than the brain
