walboro pumps??
02strokin
Chester,ohio
Are they good pumps??? Will it help my 02 out since i got stage 1's an stock fuel?? Any input is much appreciated!!
they flow more then stock but if your pump is healthy i wouldnt change it. some have had good luck with the walbros, some havnt. the key to keeping the walbros healthy is great pre pump filtration.
02strokin
Chester,ohio
I figure my is weak I bought the truck new an it now has 176xxx miles on it so if anything it has to help it I'd think anyways
Marty
Elkton, MD
Run a regulated return and monitor fuel pressure. Its not wasting money and removes the greatest pressure drop from in front of the injectors to after them.
02strokin
Chester,ohio
I got isspro .gauges just nvr hooked the fuel pressure gauge up cuz I was goin to put a air dog on it Untill I heard an found these.... Im not quite understanding the return deal tho Maybe I'm just dumb
i went 30-40k on my first one but i tore everything apart to find that there was a chit ton of metal shavings plugging the system up so it trashed the pump
tbsimmons
Bakersfield, CA
I have never ran them on a diesel but have on gas engines. Never had a problem with the pumps. Just make sure the wiring is good. I have seen them melt loose wiring.
mattman347
Readyville TN
This. Been running a Walbro pump for years, and have sold quite a few with very minimal warranty issues.
