wastegates
617mach 1x
just wondering if a 38mm is big enough? i have a chance to get a tial wastegate off a friends car cheap
going on my truck with a 68fmw (.90 housing) and 205/100s going to run NOS thats why i want to put a wastegate
motoxracer42
diaphrams and diesels don't always work well together.
what would you depend on. left or right
motoxracer42
I just looked at the pic and saw metal shavings everywhere and realized I was machining parts on a gun over my wastegates lol. oops
imelmo
I know zero about wategates (just as with most other things LOL ). What determines how big of a wastegate is needed and why?
617mach 1x
Probably 100shot or something of that sort
Yes does look like the left is more dependable
My turbo should keep temps in check with 205s and the gate was only 60$ so hard to pass up
Motox what kind of gate is that on the left
Mostly was wondering how to size it properly?
motoxracer42
the left side is a jgs 50mm. the right is a tial 44mm. honestly a 38mm will work fine. with that charger you can cap the gate off when not spraying. there wont really be much for room to spray. the only external gate I have left on my truck for driving is a jgs, but they will fail as well if they are setup wrong, like 99% of the ones ive seen.
617mach 1x
Eventually I'm going with a set of 265 hybrids that'll should give me plenty of extra fuel to spray with
What are you recommendations for setting it up? I was going to use the old egr location to mount it and run it back into the downpipe
motoxracer42
if your going to run an s400 frame charger, you shoudnt have a set of stock up pipes. I would run a jgs 50mm. ill shoot you a pm
stroker 6.4
I'm goin to be running a jgs 50mm on my 6.4 set up any tips and tricks to setting it up correctly? First time I've ever messed with a gate
motoxracer42
run boost to both the top and bottom port. run a regulator to the bottom port set to around 15psi to start with. the higher pressure you have the reg the sooner the valve will start to lift.
setting them up this way is the proper way. it actually opens the gate off of pressure on the face of the valve.
617mach 1x
could i run my wastegate in that location, even if its only relieving pressure on one side more then the other? id just vent it to the atmosphere after
6 L chevy eater
Franklin, VA
on my gate , i have full boost to bottm port and regulated boost to the top port, this is the way iwas told to set the gate up up on my truck, i running a Tial 44mm
