96OBS
Okay guys, the other day out of the blue, my water in fuel light would come on when I made a sharp turn the off. Then it would come on then off immediately. Now it is always on. Havent had this problem until I installed my flatbed and had to modify my mounting spot for the fuller tube. I had to cut a hole in the bed and then cut off part of the metal tube exposing the small rubber one. My filler cap is on top off the bed. Do these lids seal good? Also my fuel gauge goes on the fritz every once in a while, if its real cold it will say completely full but when I start driving it will go back to normal? Could it be a ground on the tank maybe? I'll try to post pics...
