Weid Starting??
Nic
Santa Fe, Texas
i know it could be a number of things..chaffed wiring harness, hpop, ipr valve etc, but it has done this ever since i bought the truck back in 2009...has anuone else had this problem and had the issue adressed? WHAT WAS IT???
no matter if the truck is cold or hot, it has done this..since 09, ive had all the work done and it STILL does it. had cam and crank sensors replaced and all issues of the truck adressed
sometimes she fires right up on the first turn, others it takes LONGGG crank times..others it fires over first turn but chuggs up to an idle and lastly some times it cranks forever and then chuggs up to an idle....never the same. seems to start better in a hot tune though. ???
i guess im leaning toward chaffed harness???
Nic
Santa Fe, Texas
wouldnt hpop issues be only on hot starts though? wouldnt it be toast after 3 years of doing this? it also sounds like something is real whiney in the motor bay when its driving..like having a hard time operating. almost like a power steering whine, but ps fluid is good and doesnt whine
Mdub707
Mohawk NY
You just need to read the pressure coming off, doesn't mean the HPOP itself is bad. Measure ICP desired against ICP actual and the IPR duty cycle. it will tell you what's going on. Could be as simple as a bad ICP sensor.
Atsah
Maine
Had the same problem for years with my 6.0, changed all kinds of stuff.. I fixed it by selling it..
Nic
Santa Fe, Texas
hahaha...well, i got a little too much money invested in this one to let er go...had NO IDEA what i was getting myself into when i got it. Just wanted to get rid of my 7.3 for that good whistling sounding 6.0! dont get me wrong i love the hell out of it and ive put 15 grand into it so far but shes my first and last 6.0 lol
Atsah
Maine
My first one didn't cost me a dime, the second one, well no so good...:fustrate:
well the horse is purty reliable, but it can bite you in the rear too. an when it bites it really bites. if its not biting, its kicking
