Extended Power
- Joined
- May 24, 2011
- Messages
- 2,216
- Reaction score
- 0
It's my father-in-laws truck.
It's a 2009 F350ccsb 4x4.
It has a DPF delete, AFE air filter, and a H&S Black Max tuner, which is always set on the hot tune.
We took it to the dealership, and the tech used a stethescope to see if he could pin point the issue, but could not.
He hooked up a laptop, and plugged into the OBDII connector, and said "this is a cheap way to do a compression test". (Not sure what he did.)
It runs smooth, no smoke at idle...no miss.
Tech said it had good compression.
Truck has 145000 kilometers. (~80k miles)
I thought it might be rocker arm, or pushrod.
Tech said it might be a lifter.
It follows the engine rpm.
Any ideas from people who have heard this noise, or suggestions of what it might be?
http://vid1141.photobucket.com/albums/n581/ExtendedPower/Mobile Uploads/20150720_143622.mp4
