Steve's red stroker
Truck starts and runs but often it seems detuned only builds around 22psi of boost and no power, you don't notice it much just cruising but if you put it down its just not there. I can throw it in neutral shut it off and restart it and then it's back to normal. Once it runs like it's supposed to it stays like that until you shut it off. Go to start it back up and you never know if it'll go good or bad until you put it down. It'll stay running good or bad the whole time until you shut it off then you never know what you'll get. I changed my PCM and tried running it without tunes and it'll do the same thing. So it's not a tuning issue. And the only codes I have are for the intake heater and ebpv which are both deleted. So I'm kind of clueless right now
