What are the hp numbers for Gearhead tunes
strokin20
brownwood, tx
I'm runnin his race tune. It feels like its got as much power as any of the other tunes I've ran, shifts smoother and smoke is practically non-existent. If it works out I'm going to get on PSM's dyno sometime between April 23-26 and I'll have some numbers. His tunes are def worth the money.
Dzchey21
wyoming
not sure on numbers from stock trucks but his modified truck tunes are competitive, i didnt dyno mine with any other tunes, but i will say that making 850 hp on a tune i drove the truck everyday on says enough. Matt told me the latest tune i got from him should make 900 hp but i never did dyno it but it did feel stronger.
extreme3807
Bucyrus, OH
I think i am going to give his a race tune a try before TS. Just trying to collect as much information as i can about it, thanks
Sent from my DROID Pro
Dzchey21
wyoming
i can understand, his tunes are cheap and can go on your livewire in the custom section so you can run IDP and his at the same time, no need to load stock, so if anything you could make a test pass, do another tune and make another pass, check your mph and see which is faster mph wise. Might want to get one now and he can adjust the trans tuning as needed for your single set up.
extreme3807
Bucyrus, OH
Thats the plan, once i get the new trans in I am going to do some back to back passes. If in doubt matt's are better I will definitely have him tweak some minor things
Lowdown89
Travelers Rest , SC
Sorry for the derail, when you gonna have the tans back in? Once I get my trans and everything buttoned up on my truck I would like to come down to where ever you are gonna run and make some passes as well.... I won't be anywhere as fast as you lol but I would be fun
Ok back to tune disussion! :eek:fftopic:
extreme3807
Bucyrus, OH
Hoping to have everything back in and buttoned up for Virginia and TS next month. Whenever i get it running I will give you a shout bud, probably see you sometime next month
extreme3807
Bucyrus, OH
What track times have been made with these tunes? I am just looking for track times instead of street manners.
MINK
London,OH
I had planned on going to the track friday but my stock trans wont hold - times should come out the closer we get to summer.
