What fluid for rear diff
littleredstroker
where the antelope play
Hope this is in the right place, gonna change fluids in my rear end and am not sure what to go with, I don't really care to go to a synthetic unless someone can sell me on why, and I don't want to order anything online, the cover is leaking and I need to do it tomorrow.
Also, just use rtv on the cover? Or what
autocorrected by taptalk
PatriotHauling
Ventura, CA
75w140. You MUST use a synthetic, Ford says so. If you have a limited slip you will need an oil with the LS additive (it will be clearly labeled) or get some off the shelf, best to get that from Ford.
Most good gear oils will have the LS additive.
Yes, RTV is used on the cover.
PatriotHauling
Ventura, CA
You can check your door tag too. Under AXLE is a 2 digit code.
Axle Type
31 — 3.73 non-limited slip, F-250/Excursion
C1 — 3.73 limited slip, F-250/Excursion
32 — 4.10 non-limited slip, F-250
C2 — 4.10 limited slip, F-250/Excursion
33 — 4.30 non-limited slip, F-250
C3 — 4.30 limited slip, F-250/Excursion
36 — 4.56 non-limited slip, F-250
C6 — 4.56 limited slip, F-250
