what hpop is better for the 6.0l early or late model
e.nickkk
which hpop is better have both and building a engine what does everyone perfer thanks guys
TooMuch03
West Bend, WI
In stock form, the 05-07 flows more than the 03-04 ones. But, at the moment, the only upgraded HPOPs available are for the 03-04 pumps and they will significantly outflow the stock 05-07s. It won't be long before an upgrade for the 05-07s is available.
e.nickkk
I have both set-up just didnt no what hpop to go with 175/75 injectors
AirFishAutomotive
DELAWARE
It sounds as though both pumps are interchangeable, correct?
No they are not.
If you were to go to early hpop to late you would need to change
pump
Pump cover
Icp
Oil rails
Stand pipes
branch tubes.
To change branch tubes heads come off.and rear cover so easier if engine is out
they interchange as in they bolt into the same area the same yes
