Is there just a bit of it inside the valve covers, or does all the oil look like coolant has mixed with it? I've seen a few trucks that get what I can only guess is condensation under the valve covers. But I'd drain the oil, set a new bucket under the oil pan, leave the drain plug out, and pressurize the coolant resovoir to 15-16lbs, and let it sit.
It is seafoam. The customer finally confessed of 2 things. 1. He has run wvo, homemade bio, veggie oil and waste motor oil.
2. He hadn't changed the oil in 2.5 years before the first time I did injectors (12/30/13)
Moss Diesel Service
