what to expect?
da94broncodude
WJ,UT
Heading to the track tonight to see what my truck does, id like to back up my dyno numbers to know if theyre legit or not, truck put down 520 on industrial injections dyno, which seems high to me but if i can back it up on the track that would be great. mods are the usual intake exh etc and then a powermax with 175/75 injectors, i know i have a couple things against me lift tires etc, but my friend with the same setup with no injectors at this track and 35s 20s (i have 35s 22s) ran 14.3 here are my ?s
what should i expect to run? what kind of 60' should i be shooting for?
do any of you guys have pics of where your strapping the front end?
what psi should i shoot to launch at
what psi should i run in my tires? (hankook dynapro atm 65psi E rated)
05wh250
hendersonville, nc
I just ran the straps across the frame rails and under the radius arms and hooked the straps to thereself. I would start probably about 10 psi and go from there. Tires I've heard 25 in the back and 30 in the front. Also lock your hubs manually and have fun! But make sure you can air your tires back up before you get back out on the road.
Redneck6.0L
1.8 60fts, 13.5@101mph maybe 13.2@101 for that hp. 520hp on stock rubber no lift would run 12.8
da94broncodude
WJ,UT
Just made first pass
Tires @ 40psi front end strapped
rt .147
60' 1.846
330 5.640
1/8 8.887
Mph 75.38
1000 11.704
1/4 14.090
Mph 93.98
Sommers
joey i seen your truck last night at rmr nice looking truck very smokey lol
i ran a handful of 13.9s 13.8s and 1 13.77 with my old 6.0 @93-96mph at rmr 1.75 1.80 60s
mods
SCT INNOVATIVE EXTREME TUNED, S&B CAI,SUNCOAST TRANS,300M BILLET INPUT SHAFT,BILLET CONVERTER
5"FLO-PRO EXHAUST,LEVELED W/35S ON 20S
here is a video of my first run down rmr i weighed my truck at 7800lbs
http://youtu.be/u1MyOnQpVYQ
da94broncodude
WJ,UT
Sommers- that's funny I've seen your video before cause a friend of a friend bought your old truck.
I think my Trans is hating it's life, been shifting funny lately, might have to freshen her a bit.
imelmo
If your truck was 8000lbs you should be trapping about 98mph for that dyno number which would be a mid to low 13.
For the dyno number you have to be correct at your 94mph trap speed, the truck would have to weigh about 9200lbs.
Sommers
Yeah my stock trans hated the 4wd launches, how's the truck running these days? I got rid of it with just exhaust and trans it was missing the parts to make it run fast.
imelmo
That puts it around 480rwhp. That's a heavy truck! My orange truck with 37x13.5's and a winch on the front was only 8300lbs.
imelmo
What should a cc short bed be weighing? It's been awhile but I was thinking I rolled across the scale at 8850 at the local fertilizer plant.
Well this:
Was this truck including me and half a tank of fuel, nothing removed, tailgate on. Just no spare tire. Weighed at a certified CAT scale:
Before the lift and everything it was 7500 or 7700 in stock trim with me iirc.
That's not to say his truck couldn't weigh that much though. Weights seem to be all over the place with these things for some reason.
da94broncodude
WJ,UT
I don't exactly have my truck race prepped lol, obv it's a lifted ccsb, but I'm sure the weight is a lot of my accessories. The entire roof, pillars and back half the cab up to the drivers seats on the floor have been dynamatted, it has a tonneau cover, Titan 52 gallon tank, subs 2 amps etc
