Power Strokes
7.3 Aftermarket
what turbo after a 38r
[QUOTE="TARM, post: 665040, member: 578"] Yep IMO the 4294 is almost ideally matched as "do all" turbo for the 7.3. It tows well it spools up quick, has very little lag. The flow is matched well to the 7.3. No its not near as configurable as s300 s400s so if you want to be changing wheels and housing etc that's a different game. Even the journal bearing is good for 600 with some 200%. Of course this is only one person opinion with mild experience and there are people on here that have been and use all sorts of turbo configs. I will say be sure to hook the water connection up. Even if you just hook it simply into the heat lines. Get water too it. According to the Garrett tech a member hasd spoken to the one with water pickup do not have the same heat sinks or whatnot that the oil only have so oil alone does not provide the same level of cooling on these. The water is needed. Especially for hard runs or long runs under med higher boost. All I can say is what I was told. I got the hook up Matt (gearhead) recommended with the banjo bolt hook ups as it makes it nice and compact. Himni Racing sells the kit for $25. The banjo plus proper PL for 6 hose. T into a heater line. It works off of thermal flow. I have the X version and its eery quiet. I assume this is because of very tight tolerances which for the cost it better be LOL [/QUOTE]
GT37 Turbocharger w/10 blade turbine, billet comp.
Latest: hskfab
Yesterday at 1:24 PM
Engine and Drivetrain
Hard steer question/issue
Latest: psduser1
Thursday at 8:52 PM
7.3 Tech
B
WTS/WIF light flash and stall issue
Latest: blickcd
Thursday at 6:23 AM
T
2013+ steering gearbox in older trucks
Latest: TPOLO
Wednesday at 11:09 AM
J
15 cab on 08
Latest: jeretl
Monday at 2:38 AM
Aftermarket Super Duty 1999 - Current
Power Strokes
7.3 Aftermarket
