what wires do i tap into
Raptorgabe
I need to know what wires to tap into to wire the factory camera to my new headunit any help would be greatly appreciated !! or what I need to do to get it to work its a 2012 f350
Supereco06
New Haven
Rear Video Wire Colors
Video+ - white/green
Video- - Brown/purple
Gray 10 pin plug on back of radio, pins 1 and 6
Raptorgabe
thanks man got it to work ! when i go to av i can watch it while driving ! can i jump the camera power wire to the reverse light to make it come on when go to reverse or no
Supereco06
New Haven
If it is functioning while driving all you will need to do is run a wire from the reverse input on your head unit to a +12v reverse trigger somewhere. That will cause the radio to jump to the reverse source if you have it hooked up to the backup camera input on the radio.
Without knowing exactly how you have it currently hooked up I am just speculating.
