Whats wrong?
dieselpower
Best Coast
when my truck (05 6.0) is cold, the exhaust fumes in the truck cab get really bad. Also, with the tuner on the high level, when i give it the green one smoke wil come through the vents into the cab. what could be the problem? i'm thinkn maybe the up-pipe is leakn...? also, it seemd to get worse aftr the egr cooler wz replaced under warranty...could it be loose or somthn? :confused: thancks for the help!
Fox'sFord
Hamilton Bermuda
I would think exhaust leak. Set your tune to whatever smokes the most, have someone give it some throttle, and see if you can see anything under the hood.
Abrannan19
Probably a cracked passenger side up pipe..very common for them to crack in the flex section.
