where should i be hp wise
97f350greenmachine
high im new to the disel world just got a 97 f350 rclb 4x4 has 3.55s its an auto i just order a bucnh of stuff and wanna know bout where il be hp wise adrenaline hpop irate fuel system 235cc 100% injectors high voltage icm intake tubes beans intake 5" diamond eye exhaust s&d i think cai ts 6 position ats stage 5 transmission with converter and a dieselsite wicked ball bearing 66mm turbo and an intercooler kit and yes the ts is programmed for my injectors also doing valve springs and pushrods and head studs
Petro
Lincoln Nebraska
With everything correct tuning wise, you should be between 5 and 550 easy enough. Probably on the lower end but a fun setup either way. Put together a ton of setups just like this and people were always very happy with the outcome.
97f350greenmachine
might do a cam when i get more money i know my bottom end is my limiting factor right now but im hopin shell hold atleast till i get bored and want a bigger turbo
