true98jeep
Looking for some advise from guys who have swapped gears in their trucks as to which route I should go for my 07 6.0. First of all the Truck is studded heads are o-ringed all the reg bulletproofing done. Truck has a stage 2 Barder, Absolute Apex Manifold, Mishimoto Intercooler, Precision Industries 1600 Converter, Billet Input Shaft and will be going with 175/30 injectors. I have a 4" Carli lift and 37' Toyo Mt's. I have sat and done all the math. The truck stock came with 3.73's and the 285/75/18 right at a 31" tire. If I go 4.56's the truck will be geared just slightly lower than stock turning approx 100 RPMS higher at highway speeds 55+. If I go with 4.10's the truck will be geared higher than stock and will be turning approx 200 RPM's lower at 55+. I am thinking 4.30's may be the perfect match as I may drop down to 35's for towing purposes when wanting to use the truck as a truck and not a grocery getter.
It is not a race truck I do not drag it I do not hot rod all around town it is the funnest daily driver I have to enjoy and use as a truck. I am putting in Trutrac's front and rear and this may be the easiest deciding factor the gear range split for them is 4.10 and higher or 4.56 and lower. Can anyone definitively advise me if the 4.30's will work with the 4.56 and lower carrier?
Any real world experience/insight is greatly appreciated I am trying to get this done and dusted before I come home in July to put the truck to work and use it for the month. Thanks guys for your help, I am hoping I may be able to come to a definitive decision on which way to go and get this into the shop.
Thanks,
Nick
Thanks,
Nick
