Cknox121
Driver side manifold. Think it's cylinder #8
No oil loss, coolant doesn't fluctuate.
Is it oil for sure, or maybe some nasty cocktail of coolant/soot? I know when my EGR pipe was cracked it looked similar to that. The condensation/water inside that pipe would leak out and run down onto the up pipe/manifold and made me think I had a problem at the manifold flange area at first.
I checked on top of motor and as far down as I could see. Seems to be coming from top of uppipe flange.Look higher for the source
I was thinking bellow, but I don't see any soot on fire wall.
you would have a nasty exhaust leak to have that. looks like oil to me, could be valve guide seals
When mine went the bellow was fine, the pipe itself cracked where the mounting tab was below the bellow and that's where it was comming from. I didn't have any soot on the firewall either.
no its just from the seal riding up on the valve, if indeed that is the case. Generally you get a puff of grey smoke on start up but other than that its not really noticable
could the glow plug harness be popped out? also check the rubber grommet on the top side of the rocker box that seals off where the high pressure fuel line passes thru it.
Glow plugs in place. I forgot about the fuel line though
I did notice a puff of grey/whitish smoke the other day after letting of the pedal. Couldn't get it to do it again though.
Turbo seals toasted?
Think I figured out where it's coming from. Turbo.
Boot blew off and hot side had oil in the bottom of the piping. Guessing it's going threw intake? Haven't notched any smoke on start up though.
Didn't you just put that charger on?
