All my buddies with YJ's used to constantly invert their shackles by ramming them into rocks and ledges when we were offroading. Talk about pissing away a good half-hour trying to get a shackle to flip back out.
For a vehicle exerting a lot of force on the frame via the front axle, I'm not sure that having the hanger in the rear, placing the spring in tension wouldn't actually be more stable than having the hanger in the front with the axle trying to buckle the springs.
Although with the hanger in the front I suspect the downforce would be greater as the axle would generally try to lift the front of the truck as it pushed forward, whereas with the hanger in the rear it would tend to pull the truck down.
Lastly, my superduty is a raging pile of fail in terms of front axle control in 4x4 in a hard pull, whereas my OBS is straight as an arrow.
But one has 4 times the hp as the other, and a standard steering box vs an orbital valve and cylinder.
