Will Crank case vent help exhaust smoke??
rrod
When I have my truck on straight pipe it has a steady stream exhaust smoke at idle and under light acceleration. As of now it can only be 2 things in my mind...1) bad turbo seal which will brad rebuilding or 2) blow-by in crank case.
The truck hasn't burned any oil in 4,000 miles or antifreeze. If it was crankcase smoke would a breather on the crank case help relieve some of that smoke?
Just wondering my options so I can out straight pipe on to delete the regen cycle and hope not to smoke so much at stop lights
does it have a delete tuner installed? or just a straight pipe.
rrod
I have spartan tuner. Definitely has a haze while idle at a light. Just didn't know if vent to rear wheel well area would help?
