will it fit?
NCPowerStroke
i have an 04 F250 6.0, and im wanting to put some larger tires on it. i have a couple questions....
1. will it affect my COMPLETELY STOCK engine (no new studs, heads) if i put larger tires on it? (very dumb question, but i dont want to blow any heads, or mess anything up)
2.will i need a leveling kit to fit 33x12.50 tires?
3.what is a good nice looking cheap rim (190-200$ a rim)
4.what off set/backspacing would i need
could any one post pics if you got em? thanks:)
Agjake11
Rosenberg TX
No worry about it messing with the motor. You can fit 33x12.50 stock height with a wheel that has 4.5" of bs.
I have 20x10 -24mm offset wheels with 305/55/20 tires and stock suspension up front and 1" block in back.
Agjake11
Rosenberg TX
Ground in the last one is sloped towards the front
JoshH
Op,
4wd or 2wd? Makes a difference. I'm running 20x9 et0 (5" backspacing) w/ 305/55/20 (33x12.50) but I'm 2wd. 4wd may have less clearance because of the leafs up front.
Agjake11
Rosenberg TX
Love this truck. Puts ALOT of ideas in my head. Need to go for a spin since you've done more since I saw you last.
ha thanks man. ill be around still when i can and we can have another track day soon and ill be there forsure
I see you have Fuel Throttles. I've been looking at some. Do they make them in 18x9? I think they do but I'm not 100% sure
yea i think they ahve them i 18x9 and 18x10. still need 4.5" of BS for 4x4 trucks
03 tx pwr stroke
Texas
Sounds good. Unfortunately, I won't be going down the track until I get a new trans and tunes. Just gotta see how much it's all gonna cost me. I have a few leads but I'm still chasing a few more.
OP, sorry for the derail.
