work truck project
obs444
im in the process of building my obs 7.3. eventually this truck will do nothing but pull trailers and work around the farm. i already own a truck that is slowly becoming nothing but a toy. i was wondering if anyone has any ideas? im shooting for a reliably 400hp.
obs444
shes all stock front to back. its got 190xxx on the truck and the tranny is going to need rebuilt very soon. im starting from square one on this truck
Dieselboy.
Surrey B.C.
4" Exhaust
6637 Intake
6 POS Chip with your flavour of tunes
Regulated return with 1/2 fuel lines, I prefer dual SD pumps in case one fails you arent stranded.
Gauges, I like gauges so I can watch my engine, dual pyros are a must, boost and back pressure, trans temp if auto and a scan gauge.
And trans mods, whether its a new clutch or rebuilt auto with billet TC and valve body at least.
Some things also to consider are a new set of valve springs, pushrods and headstuds. Although not needed, but for 1000$ out of pocket for peace of mind. Why not.
I would say you could do stage 2s and a d66 would be your cheapest bet. But personally what I want to do for an tow pig OBS is:
All of the above basic mods
T4 mount from Irate
S362-S366 size turbo
Definately install an SD intercooler
And a set of 238/80 hybrids
I know these are a little bit bigger than needed for 400hp, but Id rather have a little room to grow, with an s366 this setup would be a solid 425ish HP truck without high egts in a hotter tune, and a solid 300HP tow tune.
Estrogen Hostage
400hp is a lot for yanking trailers around on the farm. It sounds like a good way to be breaking axles and other parts on it with too much HP. I am doing a similar build on my truck. It's getting a 40hp tow tune with AC injectors and a 4" exhaust. I wouldn't go any hotter than that myself.
Farm work is tough on trucks, and you're not going to make it more reliable by adding more HP. I can't think of a single instance that I needed more HP than what I have completely stock on the farm.
