WTB: 05+ DRW 4x4 front & rear axles and suspension components
clifdawg
As title states, looking for front & rear axle assemblies and all the suspension components that connect between axles and frame. I'm doing a swap on my OBS dually.
They must be Dual Rear Wheel and 4x4 from 05+ super duty. 3.73 or 4.10 will work. Not sure if I want 4.30, but if they are cheap enough, I can always swap the gears.
Thanks!
clifdawg
Thanks. Keep me posted and I'll keep you in mind. Would really like to buy everything off same chassis, though if possible. Because I will also need spring perches, etc off of the frame to convert my 91. A rolling chassis would essentially be the best find for me.
