WTB stock fuel rails 6.4
IBSTROKIN
Hammond,LA
I can't take the bouncing and bucking down the road at 55mph. FRP swings and causes a bouncing affect even with cruise set. I do not have a fuel bowl delete but I don't think it would help.
Strokin6.4
Not to derail but are you running stock pump and stock nozzles? And whose tunes. I'm going to ported rails just curious if I should expect same deal
Sent from my SCH-I500 using Tapatalk 2
Spatel23
Olive Branch, MS
I'm on my phone so I can't tell but jar tunes are you running OP?
Another thing to try would be to unplug the fuel temp sensor. Dustin discovered that this works.
MINK
London,OH
I did this on my stock fuel truck with fuel bowl to no avail, worth a try regardless though.
I think the op has tried a few diff tuners, I had it the worst with my ID xrace but it is a race tune afterall....Matt@ gearhead fixed all my issues.
IBSTROKIN
Hammond,LA
Yes stock pump and nozzles
IBSTROKIN
Hammond,LA
Yes I have tried just about every tune out there. KEM,SPARTAN, Gearhead, etc...
dstryr
Gilroy CA
My truck did the surging with stock rails so I dont know if going back is going to help you? I'd try doing the fuel bowl delete since it is a good mod anyway and see if that gets rid of it. Do you have traction bars? Traction bars seemed to help mine a good bit.
IBSTROKIN
Hammond,LA
I think we might be talking about two different issues. This is a violant quick bouncing effect is the best way to explain it. Only happens when the TC locks and boost drops off and only while applying light throttle. This was not an issue before my build with the same tunes. The only fuel mod I did was ported rails. I have not installed my traction bars yet. Jeff at Spartan has the same exact issue and I believe he has traction bars
dstryr
Gilroy CA
Mine did the same thing horribly stock when on extreme race and sometimes on extreme street. The OUO bars really helped the bouncing a low rpms with the converter locked. If you already have them I'd install it and see the difference before you sell the rails. It has to do with the sensitive fueling on the pedal and road bumps. I believe the new tunes seem to fix it? I can't elaborate on that because my truck has been down for 2 months now....
IBSTROKIN
Hammond,LA
Mine does this with the cruise set also so not sure it's a sensitive pedal. It's like the stock pump does not get along well with the ported rails when it has to control volume and pressure at low rpms
